[GRASS-dev] still compilation problems on iMac with GRASS 7
Michael Barton
michael.barton at asu.edu
Thu Jul 24 21:53:23 EDT 2008
On Jul 24, 2008, at 6:42 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> Below are the errors. They simply don't make any sense. Neither of
>> these sections of the code have been altered in a while. But that
>> shouldn't matter. What compiles on my MacBook *ought* to compile on
>> my
>> iMac.
>> Any suggestions as to where to start to look to sort this out?
>> anthgradpc7:grass7_src cmbarton$ cd ./lib/external/shapelib
>> anthgradpc7:shapelib cmbarton$ make
>> gcc -I/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
>> darwin9.4.0/
>> include -arch i386 -Os -fno-common -DPACKAGE=
>> \""grasslibs"\" -
>> DPACKAGE=\""grasslibs"\" -I/Users/cmbarton/grass_dev/grass7_src/
>> dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-darwin9.4.0/
>> safileio.o -c safileio.c
>> safileio.c:83: error: syntax error before �SADFOpen�
> Has shapefil.h been corrupted?
I just updated from the SVN. I guess I could delete everything (in
case the shapelib issue is a red herring) and update again. Maybe
that's the answer. At the end of the day, before heading home, I
updated and compiled develbranch_6 and it worked fine.
Michael
