[GRASS-dev] still compilation problems on iMac with GRASS 7
Michael Barton michael.barton at asu.edu
Thu Jul 24 22:05:04 EDT 2008
On Jul 24, 2008, at 5:11 PM, William Kyngesburye wrote:
> On Jul 24, 2008, at 6:42 PM, Michael Barton wrote:
>> Aarrgh!
>> I reupdated from trunk, recompiled TclTk from source, reinstalled
>> your newest frameworks and I still get errors compiling GRASS 7 on
>> my iMac. AFAICT, same OS and setup as my MacBook: OS X 10.5.4 up to
>> date, same config string.
>> Below are the errors. They simply don't make any sense. Neither of
>> these sections of the code have been altered in a while. But that
>> shouldn't matter. What compiles on my MacBook *ought* to compile on
>> my iMac.
>> Any suggestions as to where to start to look to sort this out?
> Mysterious.  I wonder, did you copy trunk from the MacBook to the
> iMac at one time, then updated trunk on the iMac?  Maybe something
> got messed up there.  Try a fresh checkout of trunk on the iMac?
I didn't copy this from someplace else, but I'm going to delete
everything and update from scratch. I've managed CVS and SVN
independently on both machines, but try to keep them in sync.
Michael
