[GRASS-dev] matplotlib example script
Fri Jul 25 14:13:48 EDT 2008
Yann Chemin wrote:
> I tried it in Debian/Sid and here is what I got, a strange permission error....
> Any idea/suggestion?
	chmod +x histogram_mpldemo.py
	./histogram_mpldemo.py
Even if you invoke the python interpreter explicitly, the script will
run g.parser, which will re-execute the script directly, so it needs
to be executable. This is true for any script which uses g.parser.
