[GRASS-dev] Re: [GRASS GIS] #231: r.li.index in 6.3.1 svn doesn't
work
trac at osgeo.org
Sat Jul 26 05:21:49 EDT 2008
#231: r.li.index in 6.3.1 svn doesn't work
Reporter: leolami | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Resolution: | Keywords: r.li
Platform: Linux | Cpu: Unspecified
Old description:
> If i create a rigth configuration file with r.li.setup (es. moving
> window) and then I use r.li.shannon commands I have this error message:
> GRASS 6.3.0svn (Toscana):~ > r.li.shannon map=uso_primavera_2005
> conf=navacchio output=shannon --overwrite
> Segmentation fault
> WARNING: Can't open header file for [ in (null)]
> CHILD[pid = 3613]: unable to open mask ... continue without!!!
> CHILD[pid = 3612]: unable to open mask ... continue without!!!
> CHILD[pid = 3611]: unable to open mask ... continue without!!!
> CHILD[pid = 3610]: unable to open mask ... continue without!!!
> GRASS 6.3.0svn (Toscana):~ > WARNING: Can't open header file for [ in
> (null)]
> CHILD[pid = 3609]: unable to open mask ... continue without!!!
> CHILD[pid = 3608]: unable to open mask ... continue without!!!
> CHILD[pid = 3607]: unable to open mask ... continue without!!!
> CHILD[pid = 3606]: unable to open mask ... continue without!!!
> CHILD[pid = 3605]: unable to open mask ... continue without!!!
> CHILD[pid = 3604]: unable to open mask ... continue without!!!
> Niccolò Rigacci, with the help of Markus Neteler, has recompiled GRASS
> and now it works but there is ever somethings of wrong.
> Niccolo can you explain what did you do and where do you think the
> problem is?
> Thank you
> Leonardo
New description:
If i create a rigth configuration file with r.li.setup (es. moving window)
Segmentation fault
(null)]
Niccolò Rigacci, with the help of Markus Neteler, has recompiled GRASS and
Niccolo can you explain what did you do and where do you think the problem
is?
Thank you
Leonardo
Comment (by neteler):
Please better define:
- Platform:[[BR]]
- CPU:[[BR]]
- there is ever somethings of wrong.
I suppose it's a Debian Linux?
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/231#comment:2>
