[GRASS-dev] Re: requiring 2.8.1.1???
Martin Landa
landa.martin at gmail.com
Sat Jul 26 19:14:11 EDT 2008
2008/7/27 Glynn Clements <glynn at gclements.plus.com>:
[snip]
> wxversion doesn't *check* for a particular version, it *chooses* a
> particular version.
> If you use wxversion.select(), you only need to have that particular
> version installed.
> OTOH, if you "import wx" without using wxversion.select(), then check
> wx.version(), the desired version not only needs to be installed, it
> also needs to be the default version (i.e. installed as "wx").
> So, if you have e.g. both 2.6 and 2.8, and "wx" is 2.6, the code will
> fail without the use of wxversion.select().
AFAIU, that's CheckForWx() should do
http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/gui_modules/globalvar.py#L27
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
