[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Sun Jul 27 13:12:25 EDT 2008
William Kyngesburye wrote:
> Since the app startup doesn't have access to the user's startup
> environment, they can't set it before running GRASS.
We could do with having Init.sh explicitly source a file containing
variable settings.
> > Why not just include 2 versions of wish: 8.5 aqua and 8.5 x11.
> > Switching GRASS_WISH will make the GRASS aqua or x11 compatible.
> > These are small files and then binary users would not need to worry
> > about having TclTk installed or which version they have installed.
> I noticed something that could cause trouble in freely switching
> between aqua and X11 tcltk at runtime.  There is this 'osxaqua' env
> var (I think it came from Lorenzo a long time ago).  This needs to be
> set when running the GUI with tcltk aqua.
> In tcl scripts it's used to set keycontrol to the Mac command key and
> execom to spawn.
> There should be a way to detect the graphics system in tcltk so the
> user doesn't have to figure it out.  I poked around a bit and found that
> [tk windowingsystem]
> returns 'x11', 'aqua' and 'win32', independent of the platform.  So a
> combination of $tcl_platform(platform) and [tk windowingsystem] could
> be used to identify Mac X11 or Aqua.  I did find that [tk
> windowingsystem] opens a small empty tk window, but it's a place to
> start and maybe you know how to execute it properly.
Tk itself creates the top-level window.
I have changed gis.m to use "tk windowingsystem" instead of
$env(osxaqua).
> 'osxaqua' is also used once outside of tcl scripts, in init.sh.  It's
> used to decide whether to pipe the gis.m startup command to "sh &" or
> not.  I don't know if this really needs to be there, or if a different
> test could be used.
That code is complete gibberish, and potentially quite dangerous (if
wish writes anything to stdout, the shell will attempt to execute it),
so I have removed it.
ISTR that it's a hack to deal with the case where Init.sh doesn't have
a stdout (i.e. if it's run directly from the desktop rather than from
a terminal).
It may no longer be required with more recent versions of Tcl/Tk (or
more recent versions of OSX). If wish still needs a stdout, it's
probably better to just run the grass70 script with its stdout
redirected to a file.
