[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Sun Jul 27 15:17:07 EDT 2008
William Kyngesburye wrote:
> >> Of course, some extra detection logic is needed to check for the
> >> frameworks in /Library/Frameworks, then /System/Library/Frameworks.
> > configure doesn't autodetect paths, it only confirms that any paths
> > specified by the user work. If a path needs to be passed onto the
> > compiler or linker, the user has to supply it.
> Well, for using the system paths, a path is still needed to set the
> include flags, but not for the -F path.
> Like -L flags, they are unnecessary for default system paths (/usr/
> lib, or /System/Library/Frameworks and /Library/Frameworks), and can
> cause trouble in the search order (on OSX) if used (you get the system
> framework when you wanted a custom-build framework).
> If we don't autodetect the path, but need a path for the headers, then
> configure should not set -F if the user uses one of the system paths.
> > I take it that -framework is limited to the linker? I.e. the compiler
> > still needs explicit -I flags?
> -framework is like -L, but for frameworks - yes, a linker flag only.
AFAICT, it's like -l rather than -L.
> There is a way to  include headers without -I flags, but it requires
> changes to the sources, and it doesn't work for PrivateHeaders.
> #include <Tk/tk.h>
> looks for tk.h in the Tk.framework/Headers.
Are you sure that it doesn't work for PrivateHeaders; this suggests
otherwise (under the documentation of -F):
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/gcc.1.html
If it does work for PrivateHeaders, I would suggest using the
framework syntax for the headers (then, -F should work for both the
libraries and headers).
> >> Also, the framework option should be rejected if opengl is not aqua.
> > It's still meaningful if OpenGL is disabled.
> If linking tcltk is only for NVIZ, then tcltk should match the opengl
> setting.  The tcltk framework is always aqua, you can't build tcltk
> x11 as a framework.
Tcl/Tk isn't only for NVIZ. v.digit and the form library also link
against it.
