[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Sun Jul 27 19:56:51 EDT 2008
I'm eager to give this a try. Let me know when it's stable. If I build
with x11 8.4 and there is an option to include wish and I do it--and
then give it to someone, do they also need my /usr/local/tcltk folder?
Michael
On Jul 27, 2008, at 4:12 PM, William Kyngesburye wrote:
> On Jul 27, 2008, at 5:37 PM, Glynn Clements wrote:
>> The way it's done for OpenGL is:
>> #if defined(OPENGL_X11) || defined(OPENGL_WINDOWS)
>> #include <GL/gl.h>
>> #endif
>> #ifdef OPENGL_AQUA
>> #include <OpenGL/gl.h>
>> #endif
>> I have changed configure and associated files to treat Tcl/Tk
>> similarly to OpenGL.
>> --with-tcltk now accepts x11/win/osx (and aliases) as an argument.
>> TCLTK_{X11,AQUA,WINDOWS} are now defined in Platform.make and
>> config.h.
> Cool, that works. I also tested configuring with aqua *and* setting
> the framework path, looks right.
> I haven't run a compile yet - I didn't see any of the sources that
> include the tcltk headers get updated yet.
>> I have also cleaned up the --with-opengl=aqua case, and added a
>> --with-opengl-framework= switch (the paths are no longer hard-coded).
> Oops, now all the platform.make vars for opengl are empty, except
> OPENGL_AQUA and USE_OPENGL.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what
> does that remind me of? Ah, yes - life."
> - Marvin
