[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Glynn Clements
glynn at gclements.plus.com
Mon Jul 28 10:34:21 EDT 2008
William Kyngesburye wrote:
> >> Looks like we need the tcltk header paths.
> > In that case, I think that we're better off ditching the OSX-specific
> > stuff in its entirety and going back to -I, -L and -l switches. No -F,
> > no -framework.
> We needed the -framework flags because -l would get the system tcltk
> symlinks.
Er, not if you also use -L, surely?
> I put in the -I flags just to get it to compile, and at least the -
> framework linking gets the right framework.
> > Either it's a framework or it isn't. From what you say, it isn't.
> > Hang on a minute. If the headers are using framework names (<Tk/tk.h>
> > etc), it isn't going to find those in /usr/include.
> Ah, right. Argh.
> It's OK to mix -framework linking and unix -I include paths to those
> frameworks. It just means configuring the paths, and assuming some
> default or requiring the user to pass them in.
> /Library/Frameworks could be a good default, since the current system
> tcltk is still 8.4, which doesn't work well in the aqua form for GRASS.
Have you actually tried changing the #include directives to e.g.
<Tk/tk.h> and using the --framework= option?
The first place to try would be togl.[ch] in visualization/nviz/src.
