[GRASS-dev] New module: r.grow.distance
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Jul 28 15:57:30 EDT 2008
On Wednesday 23 July 2008, Glynn Clements wrote:
> Hamish wrote:
> > > I have added a new module, r.grow.distance, which generates a map
> > > where the value of each cell is the distance to the nearest non-null
> > > cell in the input map (similar to r.cost with a constant cost, except
> > > that you get real circles rather than approximations).
> > ie better than r.cost's knight's move / octagon. (?)
> AFAICT, r.cost gives octagons without -k and hexadecagons (16 sides)
> with -k.
> Even if that's an adequate approximation, r.grow.distance is
> noticeably faster, especially if the map won't fit into memory.
> In the process of quantifying that, I found a bug in the way that
> r.cost computes the number of segments:
> if (maxmem > 0)
> segments_in_memory =
> 2 + maxmem * (nrows / SEGCOLSIZE) * (ncols / SEGCOLSIZE) / 100;
> else
> segments_in_memory = 4 * (nrows / SEGCOLSIZE + ncols / SEGCOLSIZE + 2);
> Because integer division rounds down, if the map is
> one-point-something segments in each direction, it allocates 2+1*1 = 3
> segments for a map which really needs 4.
> [With "spearfish".]
> $ g.region res=45
> $ time r.cost -k --o start_rast=test input=one output=test.grow
> 318 rows, 423 cols
> real 1m18.267s
> user 0m2.876s
> sys 1m15.358s
> 78 seconds, of which 75 is spent in the kernel (i.e. swapping segments
> to file). At res=30 (spearfish's default), I Ctrl-C'd it after a
> couple of minutes.
> OTOH, with percent_memory=0 (4*(1+1+2) = 16 segments):
> $ g.region res=45
> percent_memory=0 318 rows, 423 cols
> real 0m1.518s
> user 0m1.477s
> sys 0m0.040s
> 1.5 seconds. A significant improvement over 78 seconds.
> Fixed in SVN trunk (r32239).
Nice work. Is there any schedule for fixes like these to make it back to 6.4?
Thanks,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
