[GRASS-dev] d.thematic.area: need for a bit of
help in C-programming/debugging
Glynn Clements
glynn at gclements.plus.com
Tue Jul 29 09:40:59 EDT 2008
Moritz Lennert wrote:
> > > To use it, you need to link the program with -lmcheck (this ensures
> >> that mcheck() is called before the first malloc()),
> > Sorry, need some help on this one. Tried adding -lmcheck to CFLAGS1 in
> > include/Make/Platform.make, but get the following during compilation:
> > gcc: -lmcheck: linker input file unused because linking not done
> > How do I link ?
> Duh, obviously this message appears only each of the individual .c
> files. Linking is done afterwards...
> Sorry for the noise,
Actually, I should have said LINK_FLAGS rather than CFLAGS1.
