[GRASS-dev] PYTHONPATH question
Michael Barton
michael.barton at asu.edu
Tue Jul 29 23:58:02 EDT 2008
Thanks for the series of explanations. It sounds like there is no
perfect solution, but that #!/usr/bin/env python will be most likely
to work on most systems.
For my own system, I might add a PYTHONPATH line to my .profile that
references both 'system' and 'macpython' site-packages. This might
help in other circumstances.
Michael
On Jul 29, 2008, at 8:37 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>>> Given that the two versions are almost identical (2.5.1 vs 2.5.2), I
>>> suggest setting PYTHONPATH to contain both modules' site-packages
>>> directories, and nothing else.
>> Or make sure the correct python is running.
>> They are similar versions, but compiled differently - one (2.5.1)
>> for OSX Leopard, the other (2.5.2) for Tiger and also-works-on-
>> Leopard. The Mac Python list would have a better idea if this a
>> workable solution, or crazy.
> Right. Python code isn't likely to care about the specific version,
> but binary extensions might.
> Michael Barton wrote:
>> The important thing is that additional libraries like wxpython and
>> matplotlib get installed for the default version, whatever that is.
>> We
>> want to make sure that a script is running the same python that you
>> get when you type "python" from the command line. If you *want* to
>> run
>> it through a different python, you should just be able to use: [path
>> to desired python] myscript.py.
>> So what is the best way to make sure that the 'default' python is
>> used
>> in a script?
> If by "default", you mean "first in $PATH", then use the /usr/bin/env
> trick.
> Of course, there's no guarantee that $PATH will be the same in all
> contexts. E.g. if you modify PATH in ~/.bash_profile, you may get a
> different result when running a script from a terminal compared to
> running the same script from a GUI application.
> If you want to guarantee consistency above all else, use
> #!/usr/bin/python in the script. But then we would need to process
> such scripts during installation (e.g. MSys doesn't have
> /usr/bin/python, and it doesn't have symlinks so you can't just make
> /usr/bin/python a symlink to the actual program).
> Glynn Clements <glynn at gclements.plus.com>
