[GRASS-dev] Re: [GRASS GIS] #246: can't overwrite vector map if
it's name is fully qualified (i.e. contains @mapset)
trac at osgeo.org
Wed Jul 30 15:10:56 EDT 2008
#246: can't overwrite vector map if it's name is fully qualified (i.e. contains
@mapset)
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:246 msieczka]:
> GRASS can't overwrite a vector map output if the output name is given
with @mapset. This is not strictly a wxGUI issue, but as wxGUI uses a
fully qulified name for output, it manifests itself there. Examples:
> {{{ v.random out=tmp at PERMANENT n=1 --o }}}
> [[BR]]
> {{{ Illegal filename. Character <@> not allowed. }}}
This is a bug in v.random. However, Vect_open_new() didn't allow fully
qualified names. Both are fixed in SVN trunk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/246#comment:1>
