[GRASS-dev] Re: [GRASS GIS] #40: Copy button on wxgrass function
forms does not work
trac at osgeo.org
Thu Jul 31 12:07:12 EDT 2008
#40: Copy button on wxgrass function forms does not work
Reporter: brian | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wxgrass
Platform: Unspecified | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:7 msieczka]:
> On Debian testing, amd64, python-wxgtk 2.8.8.1 after pressing 'Copy'
button there is also nothing in the clipboard that could be pasted into
e.g. a terminal with "right click > paste", but I can paste with middle
mouse button (both develbranch6 and trunk).
That's due to the use of {{{wx.TheClipboard.UsePrimarySelection(True)}}}
in {{{mainFrame.OnCopy()}}}.
source:/grass/trunk/gui/wxpython/gui_modules/menuform.py at 32365#L817
This causes the data to be copied to the primary selection rather than the
clipboard. An explicit "copy" operation should use the clipboard (this is
how Ctrl-C or Ctrl-Insert normally behave); the primary selection is for
the selection.
Ticket URL: <http://trac.osgeo.org/grass/ticket/40#comment:8>
