[GRASS-dev] [GRASS GIS] #180: Sqlite driver doesn't handle blank
numeric entries
trac at osgeo.org
Tue Jun 3 00:05:49 EDT 2008
#180: Sqlite driver doesn't handle blank numeric entries
Reporter: ferrouswheel | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: default | Version: 6.3.0
Keywords: sqlite db |
Platform: GNU/Linux/x86_64
grass obtained from: SVN
grass binary for platform: Compiled from Sources
GRASS Version: grass63_release
The Sqlite driver doesn't seem to handle sqlite NUMERIC types being blank.
When the the field is blank, the following is output (here it is col 8
that is NUMERIC):
D3/3: col 0, litetype 3, sqltype 13: val = 'Cortaderia selloana'
D3/3: col 1, litetype 3, sqltype 13: val = 'Pukepuke Lagoon C.A.'
D3/3: col 2, litetype 3, sqltype 13: val = 'Nicholls, V.J. and Singers,
N.J.D.'
D3/3: col 3, litetype 3, sqltype 3: val = '1997 '
D3/3: col 4, litetype 3, sqltype 13: val = 'Pukepuke Lagoon C.A.?'
D3/3: col 5, litetype 1, sqltype 3: val = '2701900'
D3/3: col 6, litetype 1, sqltype 3: val = '6093700'
D3/3: col 7, litetype 3, sqltype 3: val = ''
D3/3: col 8, litetype 3, sqltype 6: val = ''
D3/3: sqlite fetched date:
DBMI-SQLite driver error:
Cannot scan date:
D2/3: G__home home = /home/joel
WARNING: Cannot fetch next record
D3/3: db_close_database()
I don't understand why it's trying to scan a date? It works fine if there
is a value such as 0.0021 in the column. I could replace all the blanks
with 0.0, but I'd prefer to be able to keep them blank so that values
don't get confused with missing data.
I'm using sqlite3 and the up to date grass63_release branch of svn.
Ticket URL: <http://trac.osgeo.org/grass/ticket/180>
