[GRASS-dev] Re: [GRASS GIS] #181: tac command missing in OSX
trac at osgeo.org
Fri Jun 6 03:21:57 EDT 2008
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: default | Version: 6.3.0
Resolution: | Keywords: v.in.garmin, v.in.mapgen
Comment (by 1gray):
Replying to [comment:12 hamish]:
> Now we are getting somewhere. One little bug:
> `##do nothing` with no command before it is a syntax error. you would
> need to run a noop like "true".
Indeed.
> but it is better to rewrite the logic of the test so that there is no
> empty case.
> also output of `type tac` would need to be redirected to /dev/null.
Yes. And `-t` should be given as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/181#comment:13>
