[GRASS-dev] svn: undefined symbol G_gisinit
Fri Jun 6 12:41:56 EDT 2008
Yann Chemin wrote:
> some modules are complaining about this since this morning SVN:
> i.eb.rohair: symbol lookup error: i.eb.rohair: undefined symbol: G_gisinit
> I have made a clean install and still same.
> (make distclean; ./conf.....; make -j4 ; make install)
I don't see i.eb.rohair in the GRASS source tree, so presumably it's
an add-on module.
If you update the GRASS libraries, you need to re-compile any add-on
modules as well as those which are part of GRASS.
