[GRASS-dev] Re: [GRASS GIS] #22: Grass r.out.mat 64bit Matlab reading problem
GRASS GIS trac at osgeo.org
Mon Jun 9 22:53:42 EDT 2008
  Reporter:  alexice  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  closed
  Priority:  minor    |   Milestone:  6.3.0
 Component:  default  |     Version:  6.2.3
Resolution:  fixed    |    Keywords:  r.out.mat endian
Changes (by hamish):
  * keywords:  => r.out.mat endian
Comment:
 Replying to [comment:11 neteler]:
 > I have uploaded the exported Spearfish roads raster map, exported on
 64bit Linux
 > box (Mandriva 2008.0).
 I will test the file, but I think this is solved. Specifically the 64 bit
 error should be solved by:
 Glynn:
 > For now, I've simply replaced "long" with "int", as the latter will be
 32 bits
 > on nearly all systems.
 > That should fix the 64-bit problems, but it won't do anything about byte
 order.
 and thus this bug (wrt 64bit) is closed.
 A remaining problem is to fix the endian stuff.
 or do you experience something else?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:12>
