[GRASS-dev] Re: [GRASS GIS] #91: ps.map doesn't remove .tmp files when it is done
GRASS GIS trac at osgeo.org
Tue Jun 10 01:22:23 EDT 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  unspecified
Resolution:           |    Keywords:  ps.map
Changes (by hamish):
  * keywords:  => ps.map
Comment:
 Replying to [comment:2 neteler]:
 > Any objections that I apply attached patch?
 There is a problem with the patch-
 If the ps.map instructions include both masked and unmasked plotting
 commands, the plot command file will be removed after the first pass and
 the unmasked items will not be drawn because the file is missing.
 Better to move the unlink to a cleanup section at the very end of
 ps_map.c? or main.c, it already does {{{unlink (ps_mask_file);}}} just
 before exit().
 also it would be nice to observe this part of the wish:
 "They are human readable and useful for debugging, so it would be nice to
 only remove them if the g.gisenv DEBUG level was below some threshold."
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/91#comment:3>
