R: [GRASS-dev] GRASS FFMPEG support
marco.pasetti at alice.it
Thu Jun 12 05:04:29 EDT 2008
Hi Benjamin,
I succesfully built ffmpeg with the current configuration:
./configure --prefix=/usr/local/ffmpeg \
--enable-shared \
--disable-static \
--enable-gpl \
--enable-memalign-hack
>Berkeley MPEG Encoder: This is a little utility (aka ppmtompeg) used by
>r.out.mpeg to generate animated sequences of raster maps.
My current configure cuurently supports the following *mpeg* encoders:
mpeg1video
mpeg2video
mpeg4
msmpeg4v1
msmpeg4v2
msmpeg4v3
are they enough for r.out.mpeg or does it mandatory need the Berkeley MPEG Encoder?
>Extract the
>file jpeg62.dll from the second zip file to C:\msys\1.0\bin
In the current MSYS environment I'm developing I added the jpeg library built from source with MinGW (this because I already tried to link the Sourceforge library with libtiff and other libs/apps, and it failed... I don't know why... maybe built with Visual Studio?)
Here there's the configuration log of my current FFMPEG build: http://www.webalice.it/marco.pasetti/temp/grass_wip/BuildFromSource.html#FFMPEG
Thanks,
Marco
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080612/76aff5a3/attachment.html
