[GRASS-dev] GRASS 7 development started
Markus Neteler
neteler at osgeo.org
Fri Jun 13 16:54:27 EDT 2008
On Tue, Jun 10, 2008 at 7:04 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Procedure:
> Server-side:
> - announce date/time of "indent" code reformatting
> - publish the final parameter set
> - run on 7.x.trunk, submit
> - run on 6.4.branch, submit
> You local SVN copy:
> - DON'T UPDATE YET but run
> svn status
> - files with local uncommitted changes ("M") need to be treated
> with the indent command on the *unsubmitted* changed files
> to avoid later update conflicts
> - *then* update from SVN to re-sync with "svn update"
> Makes sense? Can we go ahead?
Getting curious now :)
Markus
