R: [GRASS-dev] WinGRASS Plans
Sat Jun 14 00:02:11 EDT 2008
Marco Pasetti wrote:
> > Check carefully throughout your entire implementation of wxPython.
> > For the Mac version, wx-config exists in the binaries, but in a
> > place very different from it Linux location.
> I checked carefully. No wx-config file!
> Remember that Mac is Unix-like, so it's normal that you have it,
> even if in another location than on linux; while Windows it's
> definetly another *place to live* :-)
Apart from anything else, wx-config is a bash script, and most Windows
systems don't have bash (and even if they do, they don't understand
the #! mechanism used to run scripts on Unix).
