[GRASS-dev] Re: [GRASS GIS] #118: r.patch fails on Vista
trac at osgeo.org
Mon Jun 16 06:56:37 EDT 2008
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: default | Version: 6.3.0 RCs
Resolution: | Keywords:
Comment (by marcopx):
Replying to [comment:5 jrobins]:
> Marco,
> I'm running winGRASS version 6.3.0RC6 on Vista. I configured GRASS with
the windows installer program. I tried r.patch using the spearfish
dataset, but when I
> try to launch r.patch from the wxPython GUI's menus, I first get a
security alert which
> prompts me to allow or deny r.patch.exe access to my computer. When I
press 'Allow', I
> get the following error message:
> This application has failed to start because libgrass_gis.6.3.0RC6.dll
was not found. Re-installing the application may fix this problem.
> Then r.patch.exe crashes and Vista automatically kills it in the same
manner that it
> would kill a hung program. The GUI seems to work fine afterwards.
> When I run r.patch from the menu in the Tcl/Tk GUI, I get this error:
> couldn't execute r.patch: invalid argument.
> Running r.patch from the Output-Gis.m window fails without an error
message.
> I hope this helps,
> John
Hi John,
I just built GRASS 6.3.0 on Windows Vista (Home Premium) through the
MSYS/MinGW environment, exactly as I built it on XP. I made only few
tests, but both r.patch and v.patch worked fine for me.
This said, I don't think that it depends on the new build: I think that
the problem lies on the UAC system, because it forbids third party apps to
write outside the "Program Files" and "Users/Account Name" folders,
specially if the destination folder is directly in the unit root (such as
C:\), and sometimes even if the user gives the permission after the UAC
alert prompt message;
So, disable the UAC (see http://www.vista4beginners.com/How-to-disable-
UAC) and then try r.patch with the current WinGRASS binary release (still
built on XP);
Let me know if it works :-)
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/118#comment:11>
