[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating
error for 2nd order transformation
Michael Barton
michael.barton at asu.edu
Tue Jun 17 12:26:16 EDT 2008
On 6/17/08 6:03 AM, "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi Michael,
>> Yes. This has 6 points like it is supposed to. But the transformation
>> doesn't work. Doesn't work with more than 6 either.
> from
> g.transform g=roads_streams o=2 f=src,dst,rev,fwd,fd,rd
> 274.000000 462.000000 598064.018692 4927655.934580 274.000000
> 462.000000 598064.018692 4927655.934580 0.000000 0.000000
> I get what I would expect with min number of GPSs for the given order,
> when I add some other GPSs to the points file I get non-zero fwd/rev
> errors
I haven't tried this in a couple of weeks, but when I ran this with a
current build a free weeks ago, I only got 0's here. You are getting values,
but I got nothing.
> 0.004227 0.007915
> 0.132068 0.006500
> 0.047218 0.003247
> Maybe I don't understand your point here,
I don't know if this is a function of something that is now fixed, or a
problem with the Mac.
Michael
> Regards, Martin
> 2008/6/17 Michael Barton <michael.barton at asu.edu>:
>> Michael
>> On 6/17/08 3:44 AM, "GRASS GIS" <trac at osgeo.org> wrote:
>>> #163: g.transform no longer calculating error for 2nd order transformation
>>> Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
>>> Type: defect | Status: new
>>> Priority: major | Milestone: 6.3.1
>>> Component: default | Version: svn-develbranch6
>>> Resolution: | Keywords: g.transform georectify
>>> Comment (by martinl):
>>> Replying to [ticket:163 cmbarton]:
>>>> Sometime recently, g.transform stopped calculating forward and backward
>>> error for 2nd order transformations. It simply returns 0's. 1st order
>>> transformations still work fine AFAICT.
>>> The 2nd order transformations requires at least 6 GCPs. Your input POINTS
>>> file contains 6 points. Then forward/reverse error is 0.0's.
>>> Martin
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> Director of Graduate Studies
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
