[GRASS-dev] [GRASS GIS] #192: ps.map: geogrid RGB color and
ellipsoid
trac at osgeo.org
Fri Jun 20 10:14:50 EDT 2008
#192: ps.map: geogrid RGB color and ellipsoid
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: trivial | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: ps.map geogrid ellipsoid RGB |
ps.map's geogrid command only accepts named colors currently. it should be
updated to accept R:G:B as well.
Also it is unclear to me which ellipsoid geogrid uses. I suspect it is the
current one, which is fine, but it would be nice to add an option to use
WGS84's instead, like "d.grid -w".
thanks
Hamish
ps- can we have "ps.map" added to the trac Component drop down list?
Ticket URL: <http://trac.osgeo.org/grass/ticket/192>
