[GRASS-dev] cannot build gdal-grass
Maciej Sieczka
tutey at o2.pl
Sun Jun 22 11:32:02 EDT 2008
Hi
gdal-grass 1.4.3 refuses to build against GDAL 1.5.2 r14751 and GRASS
6.4 r31801.
Details:
$ $ cat /etc/ld.so.conf.d/libc.conf
# libc default configuration
/usr/local/lib
/usr/local/grass-6.4.svn/lib
/usr/local/qgis/lib
$ sudo ldconfig
$ ./configure --prefix=/usr/local --with-grass=/usr/local/grass-6.4.svn
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for g++ -shared ... yes
checking for gdal-config... /usr/local/bin/gdal-config
using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.4.svn requested, but
libraries not found! Perhaps you need to set LD_LIBRARY_PATH to include
That's strange, because:
$ cd /usr/local/grass-6.4.svn/lib
$ nm libgrass_gis.so | grep G_asprintf
0000000000013da0 T G_asprintf
and
/usr/local/lib
/usr/local/qgis/lib
What could be wrong? This used to work couple of days ago.
Debian testing amd64.
Maciek
Maciej Sieczka
www.sieczka.org
