[GRASS-dev] Re: [GRASS-user] low radiance values after i.atcor and i.topo.corr
Markus Neteler neteler at osgeo.org
Sun Jun 22 11:35:45 EDT 2008
On Sun, Jun 22, 2008 at 3:46 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:...
> To change the format of the signature files, replace %f with %g in
> I_write_signatures(), in lib/imagery/sig.c.
I have tried that, of course it works.
But apparently i.maxlik needs a change, too, to read that properly (same
sig.c fie, I suppose). At least i.maxlik doesn't produce any better result
with the precision improved signatures.
> To change the format of the report file, replace occurrences of %6.2f
> with e.g. %g in the various imagery/i.cluster/print*.c files.
ok, thanks,
markus
