[GRASS-dev] [GRASS GIS] #194: i.fusion.brovey: remove temp region file?
GRASS GIS trac at osgeo.org
Mon Jun 23 03:54:56 EDT 2008
 Reporter:  hamish           |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  minor            |   Milestone:  6.4.0
Component:  default          |     Version:  svn-trunk
 Keywords:  i.fusion.brovey  |
 just looking through the i.fusion.brovey script I see that the cleanup()
 section resets the region to the temporary region file instead removing
 it. Which, AFAICT, is a noop and leaves a saved region file behind.
 It in not important that the WIND_OVERRIDE variable is not unset there --
 that goes away automatically as soon as the script exits.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/194>
