[GRASS-dev] Re: [GRASS-user] low radiance values after i.atcor
and i.topo.corr
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Jun 23 11:48:38 EDT 2008
On Monday 23 June 2008, Markus Neteler wrote:
> On Mon, Jun 23, 2008 at 1:52 PM, Glynn Clements
> >> > And i.smap is gibberish; e.g. write_img() calls G_is_c_null_value() on
> >> > "char"s, so that module probably hasn't worked since 4.x.
> >> i.smap works, I have tested it recently and also others use it
> >> regularly.
This is very troubling, as I have been using i.smap for sometime now
(GRASS64-svn), and the output has thus far been convincing. However, I have
only been using it with CELL input maps...
> > Oh, it may produce output, but not necessarily correct output.
> > Specifically, write_img() does:
> > if(G_is_c_null_value((CELL *)&img[row][col]))
> > G_set_c_null_value(&files->cellbuf[col], 1);
Just words, but this again points to the dire need for a comprehensive test
suite.
> > But "img" is a "unsigned char **", i.e. a 2D array of bytes. The test
> > will only succeed if the array contains the sequence 00,00,00,80 (for
> > little-endian systems) or 80,00,00,00 (big-endian systems). I suspect
> > that the test was originally against zero, but it was incorrectly
> > changed when null support was added.
> > If that's the case, the net result will be that it writes garbage
> > where it should be writing nulls, and occasionally writes nulls where
> > it shouldn't.
Is there any way to evaluate this? Would this bug only affect input maps that
are FP?
> That sounds quite ugly. But from looking at the code: is a major
> rewrite needed to fix that? Since we "just" write out classes?
> > Beyond that, it seems fairly straightforward. I have committed an
> > update which compiles without warning, but hasn't been tested.
> Backported. But...
> >> Any opinions on
> >> i.gensig
> >> i.gensiset
> >> ? Both are used for supervised classification where you have training
> >> areas instead of just looking at the pixels as does i.cluster.
> > Looking briefly at i.gensig, the algorithm seems to be quite heavily
> > based upon categories (e.g. using the Cell_stats stuff), so it would
> > need to be substantially re-written to support FP in any meaningful
> > sense.
I have never been able to use the GRASS classification routines on FP maps-
usually just results in a map of NULL data or 0.
Dylan
> ... without an update to i.gensigset I cannot test the FP capabilities of
> i.smap. It seems that it was cloned from i.gensig.
> Markus
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
