[GRASS-dev] Re: [GRASS-user] low radiance values after i.atcor
and i.topo.corr
Glynn Clements
glynn at gclements.plus.com
Mon Jun 23 13:46:10 EDT 2008
Glynn Clements wrote:
> > ... without an update to i.gensigset I cannot test the FP capabilities of
> > i.smap. It seems that it was cloned from i.gensig.
> In retrospect, it appears that it's only the training map which is
> inherently restricted to integers. E.g. i.gensigset reads the group
> maps as CELL then immediately promotes the values to "double".
> Unless there's something else I have overlooked, I should have an FP
> version ready shortly.
Done. Again, they compiles without warning, but need testing.
