[GRASS-dev] [GRASS GIS] #196: wxGUI interface hangs,
when adding maps to display
trac at osgeo.org
Fri Jun 27 07:00:05 EDT 2008
#196: wxGUI interface hangs, when adding maps to display
Reporter: rmatev | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
When I set DEBUG=4 or DEBUG=5 and then add a vector map to map display 1
(which was empty), the whole wxpython interface hangs (before the map is
added). The same thing happens, if DEBUG is set to 0, 1, 2, or 3, then a
map is loaded into map display 1, then DEBUG is changed to 4, and the
display is refreshed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/196>
