[GRASS-dev] [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Fri Jun 27 14:29:24 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Keywords: terraflow r.terraflow | Platform: Unspecified
Cpu: Unspecified |
Single Flow Direction (sfd) support in r.terraflow is broken. Even when
the -s flag is specified, multiple flow directions are used most of the
time. Patch included.
The main purpose of the patch is to support single flow directions
properly (SFD) in r.terraflow. The previous version has a -s switch for
SFD, but it is not implemented properly. Tools like Hamish's matlab
script for converting terraflow flow direction values to sfd are
incomplete and sometimes result in ambiguous because they are based on
incomplete cases in the terraflow source. With the new patch, sfd should
be supported correctly and the terraflow direction grid should only
output 1 of 9 possible direction values (0,1,2,4,8,16,32,64,128),
instead of the 256 directions it printed before.
The second purpose of the patch is to eliminate gcc 4.2 warnings of the
form
warning: deprecated conversion from string constant to ‘char*’
This required making two new C files to handle the option parsing in
C-style instead of C++. The changes are minor but touched several files.
The actual flow direction fix is rather localized. New files have been
indented according to the SUBMITTING rules
users using the default Multiple Flow Direction (mfd) options should
see no changes. Users of sfd should notice that it works.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197>
