[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Fri Jun 27 16:59:05 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Resolution: | Keywords: terraflow r.terraflow
Platform: Unspecified | Cpu: Unspecified
Comment (by adanner):
Replying to [comment:2 glynn]:
> Replying to [comment:1 adanner]:
> > Can someone double check the Makefile? I wasn't sure about this
BROKEN_MAKE flag. The modifications to the Makefile are just to build the
new C source for tflowopts.c, so if the BROKEN_MAKE flag is
C++/r.terraflow specific, I don't think there is a problem.
> BROKEN_MAKE is only required for rules with order-only dependencies
(some versions of make don't handle these correctly).
> However: is it really necessary for the new file to be in C instead of
C++? It would simplify matters to keep everything in the same language.
Yes, the new file must be in C and not C++. The g++-4.2 throws a warning
if you try to assign a string constant to a char *. E.g.,
cat test.c
int main(){
char * example = "hello";
gcc test.c -o test //ok
mv test.c test.cc; g++ test.c -o test
test.cc: In function ‘int main()’:
test.cc:2: warning: deprecated conversion from string constant to ‘char*’
In C++, the following are preferred and do not give a warning
std::string example="hello";
const char * example2="hello";
However, as the code in question is initializing a bunch of GRASS structs
which cannot use const or std::string, it is best to do this in C and link
the rest of terraflow to this C code.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:3>
