[GRASS-dev] WinGRASS Wiki Hacking
Glynn Clements
glynn at gclements.plus.com
Sat Jun 28 12:53:16 EDT 2008
Markus Neteler wrote:
> > Note: I'm building the SVN trunk (7.x). The change in question (the X
> > error handler) didn't make it into 6.3.0, but it is in 6.4-svn (which
> > won't compile on Windows until the fix is back-ported).
> Do you want me/us to backport those fixes?
Yes. IMHO, almost everything done to 7.x should be back-ported to 6.4.
Once I start on full-scale renovation (after the "indent"ing),
back-porting will become impractical. But everything done up to now
has been bug fixes and relatively minor enhancments that should make
it into any future 6.x versions.
Actually, some of that "renovation" (e.g. changes to the build system,
which don't really affect the final product) could be done to 6.4.
Although that would then make back-porting from 6.4 to 6.3
problematic.
