[GRASS-dev] Re: WinGRASS Wiki Hacking
Ivan Shmakov
ivan at theory.asu.ru
Mon Jun 30 03:13:29 EDT 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>>>> I suppose that wxPython is probably the most important
>>>> omission. The main issue here is the lack of python-config on
>>>> Windows.
>>> I didn't spent much time on it (I tried only few times to let it
>>> work without success, but I really didn't seriously try...), but I
>>> guess that the soultion would be here:
>>> http://wxconfig.googlepages.com/
>> Okay, I'll try that later.
> No luck. It seems to assume a standalone version of wxWidgets (mine
> is part of wxPython), and does nothing about the requirement for
> python-config.
Isn't `python-config' just a trivial wrapper around the
functions provided by the `distutils.sysconfig' [1] (or
whatever) Python module, made to allow simple (and conventional)
access to these functions from the Shell?
I've already suggested for GRASS to be switched to use
`AC_PYTHON_DEVEL' (from the Autoconf macro archive), which
doesn't depend on the wrapper and uses the Python interface
directly.
[1] http://docs.python.org/dist/module-distutils.sysconfig.html
