[GRASS-dev] Re: [GRASS GIS] #200: v.rast.stats referring to
deprecated function
trac at osgeo.org
Mon Jun 30 06:16:13 EDT 2008
#200: v.rast.stats referring to deprecated function
Reporter: carlo | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.3.1
Component: Vector | Version: 6.3.0
Resolution: duplicate | Keywords:
Platform: All | Cpu: All
Changes (by hamish):
* status: new => closed
* resolution: => duplicate
Comment:
Already fixed in devbr6 and trunk; see trac bug #161.
AFAIK this was only a problem in an older Windows build where the shell
script wrappers that provided backwards compatibility with the old module
name were missing.
work-around: edit the script to use the new name.
closing as dupe.
thanks for the report,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/200#comment:1>
