[GRASS-dev] WinGRASS Command Line
Marco Pasetti
marco.pasetti at alice.it
Mon Jun 30 19:59:33 EDT 2008
Hi Glynn,
> I don't see a problem with explicitly passing the -text and -tcltk
> switches whenever you start GRASS. The default will then only matter
> if the user starts GRASS manually from a console.
> Also, I'm not sure there's any point to having the batch files. You
> can just include the -text or -tcltk switch in the shortcut's command.
yes, you're right. I'll include the -text/-tcltk into the shortcut's
command.
Thanks
Marco
