[GRASS-dev] RE: [GRASS-user] r.watershed problems in wingrass
Gerald Nelson
gnelson at uiuc.edu
Sat Mar 1 12:50:49 EST 2008
With an upgrade to RC5, I am able to use watershed now too. Jerry
-----Original Message-----
From: Moritz Lennert [mailto:mlennert at club.worldonline.be]
Sent: Sunday, February 24, 2008 6:20 AM
To: Gerald Nelson
Cc: 'Charles Ehlschlaeger'; grass-user at lists.osgeo.org;
grass-dev at lists.osgeo.org
Subject: Re: [GRASS-dev] RE: [GRASS-user] r.watershed problems in wingrass
On Mon, February 18, 2008 19:46, Gerald Nelson wrote:
> I tried it without the @ sign with no success; ie, the same problems.
> Where
> I am getting success is if I use the disk for paging. I suspect some kind
> of
> memory management issue having to do with Windows. I'm copying this email
> to
> the dev list in case someone there has a fix.
I cannot reproduce the problem. Could you try with the North Carolina demo
data (you can get that from here: http://grass.itc.it/download/data.php)
and see if you get the same problem, so that everyone can try to reproduce
? Also try to run with the '-m' flag, if memory seems to be the problem.
Moritz
> Regards,
> Jerry
> From: Charles Ehlschlaeger [mailto:c.ehlschlaeger at insightbb.com]
> Sent: Monday, February 18, 2008 12:10 PM
> To: 'Gerald Nelson'
> Subject: RE: [GRASS-user] r.watershed problems in wingrass
> I wrote r.watershed before GRASS allowed the use of @ symbols. (Or, if
> GRASS
> did, I didn't know about them then.) It is possible that something in the
> init.c file is wrong. Does the problem still exist when you add
> "india_basic" to the list of mapsets and run r.watershed without the
> "@india_basic"?
> Sincerely, chuck
> Chuck Ehlschlaeger, Geospatial Science Consultant
> PERTAN GROUP, http://pertan.com/
> c.ehlschlaeger at insightbb.com, 309-255-2727
> http://chuck.ehlschlaeger.info/
> From: grass-user-bounces at lists.osgeo.org
> [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Gerald Nelson
> Sent: Sunday, February 17, 2008 5:11 PM
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] r.watershed problems in wingrass
> I'm using wingrass63RC4. I am trying to find watersheds in India. I run
> "r.watershed elevation=IndiaElev at india_basic threshold=100
> basin=IndiaBasins"
> The result after a couple of seconds is
> "category information for [IndiaBasins] in [india_basic] missing or
> invalid"
> It's as if grass is trying to read the new map before it creates it.
> Jerry
> Gerald Nelson
> Professor, Dept. of Agricultural and Consumer Economics
> University of Illinois, Urbana-Champaign
> office: 217-333-6465
> cell: 217-390-7888
> 315 Mumford Hall
> 1301 W. Gregory
> Urbana, IL 61801
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.516 / Virus Database: 269.20.7/1285 - Release Date: 2/18/2008
> 5:50 AM
> No virus found in this outgoing message.
> 5:50 AM
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
