[GRASS-dev] 2D to 3D points
Hamish hamish_b at yahoo.com
Sun Mar 2 01:20:45 EST 2008
Benjamin Ducke wrote:
> That should work but it may not exactly be easy to locate for a
> novice user.
> How about a little wrapper script for v.transform that simplifies
> this action?
> I am increasingly concerned about the number of, sometimes basic,
> geoprocessing functions that are present in GRASS but "hidden"
> in complex module options. Of course people can always mail to
> this list but in the first place it will create frustration for
> them and possible turn them away.
So we make little wrapper scripts like v.dissolve and v.centroids.
That's much better than dealing with code duplication.
but that shouldn't wrap 3 module commands together with temporary maps
etc to perform something as simple as the 2d+attr column -> 3d points
conversion. If as Maciek suggests v.transform could do the job then
it's not so bad. The v.transform name even sounds right for the job.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
