[GRASS-dev] g.list: extra whitespace issue
Ivan Shmakov
ivan at theory.asu.ru
Sun Mar 2 13:24:19 EST 2008
>>>>> Ivan Shmakov <ivan at theory.asu.ru> writes:
IS> [...]
>> As for the padding problem, I believe that a more generic solution
>> should be implemented.
> Such as the following (rather obscure, though actually obvious)
> one.
Since there were no objections, and since the extra whitespace
may trigger extra linebreaks in the W32 ``console'' window:
$ g.list
bar baz
foo qux
I've now committed the change:
http://trac.osgeo.org/grass/changeset/30423
