[GRASS-dev] Updates to wingrass-extralibs
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Mar 3 06:18:05 EST 2008
On Mon, 3 Mar 2008, Paul Kelly wrote:
> Spurred on by the work that Marco is doing, I've finally got around to
> packaging the new versions of essential libraries for WinGRASS that I
> compiled a couple of months ago. In case it is helpful to anybody, the 13MB
> file wingrass-extralibs-20080303.tar.gz now at
> http://www.stjohnspoint.co.uk/grass/ contains the following versions of
> libraries:
> xdr-4.0-mingw32
> proj-4.6.0
> gdal-1.5.0
> fftw-2.1.5 (this was before I realised FFTW 3.x is OK with GRASS)
> tcl-8.5.0
> tk-8.5.0
Just thinking over this, I realise some of those will be pretty unusable
without the correct versions of the DLLs from the Gnuwin32 packages that I
compiled them against. Unfortunately I don't seem to have properly
documented that anywhere... but it might be obvious from the Windows DLL
not found error messages if anybody has the patience for that.
Paul
