[GRASS-dev] Re: [GRASS-user] How to find out an angle between to
points on the map (for r.plane, r.lake)
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Mar 3 10:53:49 EST 2008
On Sat, Mar 1, 2008 at 7:18 AM, Michael Barton <michael.barton at asu.edu> wrote:
> On Mar 1, 2008, at 1:47 AM, Martin Landa wrote:
> > Micheal,
> > 2008/3/1, Michael Barton <michael.barton at asu.edu>:
> >>> 2008/2/29, Dylan Beaudette <dylan.beaudette at gmail.com>:
> >>> [snip]
> >>>> Thanks for the update. I don't regularly use either of the GUI and
> >>>> did
> >>>> not know about this feature. Does the patch that I submitted
> >>>> interfere
> >>>> with this functionality? I think that it would be useful to have
> >>>> this
> >>>> functionality in the old style monitors as well.
> >>> d.measure is not used in wxGUI. Display windows are not
> >>> registered as
> >>> GRASS displays (d.mon -L) [TODO, not sure how to implemented], I
> >>> think
> >>> it would be good to use d.measure or something like g.measure in
> >>> wxGUI
> >>> too instead of using Python-based function for distance calculation
> >>> (at least it would make sense for LL projections)? Please correct me
> >>> if I am wrong.
> > Michael,
> >> What's wrong with the Python one?
> > duplication of the code, and in this particular case ignoring geodetic
> > distance for LL projections.
> Well, my understanding of the direction of GRASS is that by v7, we'll
> lose all the interactive xterm-specific d.* modules. Interactive use
> will all be shifted to whatever GUI we design, rather than being hard-
> coded into a module. Simple, interactive measurement between 2 points
> on a display screen seems to me something to be handled by a GUI.
I agree completely-- despite the fact that I prefer the d.* commands
for now, an integrated approach would be nice. That said, it would be
nice to retain something like the current d.* commands. Nothing is
faster when working with a couple raster/vector files.
> d.measure will go away OR change to a module in which you enter a
> start and end point and it returns the distance between the points.
> In the latter case, it could then be 'plugged into' a GUI as a
> function to calculate distance between points interactively 'grabbed'
> by the GUI.
Sure. Until then it would be nice to have something that works, and
provides some missing functionality.
> Ignoring geodetic distance for LL projections is simply ignorance (on
> my part here) of the equations needed to do it. It's easy to
> determine if a location is LL. In that case, it should calculate
> geodetic distance rather than (or perhaps in addition to) displaying
> distance in map units. Just need to have the functions to do this
> added to the measurement methods.
> Michael
I see quite a bit of disconnect between the GUI development and core
GRASS development (I am not helping this either). It would be a good
idea to spend some careful thought, with lots of input from everyone
involved to nail down the general plan for GRASS 7. I can see a lot of
potential for hurt feelings (= lost developers) if a slow and methodic
approach is not taken.
Cheers,
Dylan
