[GRASS-dev] twekaing messages [was: r30420 -
grass/trunk/scripts/v.db.renamecol]
Martin Landa
landa.martin at gmail.com
Tue Mar 4 10:53:31 EST 2008
2008/3/4, Maciej Sieczka <tutey at o2.pl>:
> >>>> Did my adding periods break any translations? Should I delete theses
> >>>> periods? Sorry if a stupid question.
> >>> yes, it can turn translated messages to fuzzy.
> > It will most likely do since the messages are different now from
> > the previous version.
> Is any modification of an existing message going to break it's translations?
yes, when a message is already translated then translation is marked as fuzzy
> > We should be really careful with the messages. Once someone has
> > translated 5000 messages s/he will be "happy" to do it again just for the
> > introduction of a period.
> I changed much more in the messages than periods only. Will that be a
> problem?
Changing messages is not forbidden;-)) Just bear in mind that it will
break translations, so the change should be reasonable and follow the
message standardization effort (should be better documented)
Regards, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
