[GRASS-dev] WinGRASS: Xerces-C and Expat under MingW
benjamin.ducke at ufg.uni-kiel.de
Tue Mar 4 10:54:16 EST 2008
OK, compiling GDAL with Xerces-C and Expat works, with
some minor tweaks.
1. MinGW's Win32 API (3.11) collides with a function definition in
GDAL. Just move it out of the way:
Open ogr/ogrsf_frmts/ili/iom/iom_utilities.cpp and rename the _searchenv
() function so it does not collide with MinGW's own version. Change the
line (ca. 67):
static void _searchenv(const char *name, const char *envname, char *hitfile)
to:
static void _searchenv2(const char *name, const char *envname, char *hitfile)
2. As Marco suspected, libexpat.dll.a needs to be
present in /usr/lib (or wherever you keep your MinGW
libs), so not a good idea to delete it.
(still have to find my way out of the DLL hell ...)
Now I would like to work on the SWIG Python and Perl bindings
for GDAL. Does anyone have experience with those on MinGW?
Best,
Benjamin
marco.pasetti at alice.it wrote:
> Hi Benjamin,
> I'm afraid that you're doing that work right now, and not a week before :-)
> because I just released a new MSYS GRASS environment, while it would be
> perfect to also add Xerces and Expat support to both GDAL and GRASS
> (only Xerces)
> it will be on the next time
> anyway I'm not sure about Expat; did you read this?
> http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
> the libexpat.dll.a is the import static library used while building the
> shared one; it is used (with the -lexpat.dll istruction) while building
> executables
> but I hope to fail and you're right ;-)
> Marco
> *Da:* grass-dev-bounces at lists.osgeo.org per conto di
> *Inviato:* mar 04/03/2008 14.41
> *A:* grass-dev at lists.osgeo.org
> *Oggetto:* Re: R: [GRASS-dev] WinGRASS: Xerces-C and Expat under MingW
> ... and on to Expat:
> that one is very simple to fix. After the "make install", just
> stay in the Expat source dir and do:
> rm /usr/lib/libexpat.dll.a
> install .libs/libexpat-1.dll /usr/lib/libexpat.dll
> (that's assuming you have Expat installed in /usr/lib,
> of course).
> I have not actually tried compiling the whole of GDAL with
> Xerces-C and Expat support yet, only got the configure
> script to run through.
> So there might be more trouble waiting ...
> Best,
> Benjamin
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke at oxfordarch.co.uk
