[GRASS-dev] image rectification from command line only ?
Hamish
hamish_b at yahoo.com
Wed Mar 5 03:44:18 EST 2008
Nicolas MERLET wrote:
> that would be enough as my GCP are pre-calculated. however i haven't
> found any documentation about the POINTS files structure. where can
> i find it ?
it's self documenting, create a dummy POINTS file and look in it.
It's an ASCII file with labeled columns.
> moreover, assuming we use i.rectify there's no paramater to give
> points, so i suppose i just have to copy my POINT file in my image
> group so that i.rectify will be able to find it ?
yes.
another way, using GDAL, is to add in GCPs to a GeoTIFF's metadata with
gdal_translate, then use gdalwarp to rectify the image. AFAICT gdalwarp
uses the rectification code (lineage) as i.rectify, but gdalwarp is
much faster.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
