[GRASS-dev] Re: m.distance / SWIG-Python interface + passingpointers with SWIG [was: d.measure w/ bearing]
Hamish hamish_b at yahoo.com
Wed Mar 5 04:22:31 EST 2008
Michael Barton wrote:
> This is why we should have a non-interactive version of d.measure.
> We've been slowly getting non-interactive versions of key command
> modules over the past couple years. A command that returns the
> distance between two xy coordiates would be useful. As I said
> earlier, modifying d.measure (or as Hamish has suggested, creating
> a new m.measure) would be desirable.
swig/python/examples/m.distance is written and fully functional.
(maybe a few slight glitches remain, I don't know- test it!)
Porting that to C, with bits from d.measure and r.profile would be a
trivial thing to do if there is demand for that.  r.profile with a
dummy map and disregarding the '*' null data won't work as the res=
must approach 0 before the segment length becomes accurate. I'm not
sure if r.profile uses great circle distances or not, I assume it
would.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
