[GRASS-dev] Re: diglib and x86_64 problems
Henning Lorenz henning.lorenz at geo.uu.se
Wed Mar 5 10:54:30 EST 2008
Hi William!
No, I'm not aware of this issue - simply because grass compiled without any
errors in diglib. The vector commands I use right now, mostly v.digit, work
fine.
Henning
William Kyngesburye <woklist at kyngchaos.com> wrote:
> I don't know about the missing symbols problem, but are you aware of
> the OSX 64bit issue in diglib?  There is a bug report (got stuck on
> the old gforge tracker, and is misnamed):
> http://wald.intevation.org/tracker/index.php?
func=detail&aid=572&group_id=21&atid=204
> When you built it a couple weeks ago, did you see any problems running
> vector commands?  I built from SVN sources a week ago and still had
> the problem.
> On Mar 5, 2008, at 8:36 AM, Henning Lorenz wrote:
>> Hello!
>> I compiled GRASS 6.3.cvs for the x86_64 architecture about two weeks
>> ago. After a svn update today (30478) I get the error "ld: symbol(s)
>> not found for architecture x86_64". Have there been any changes
>> which could cause this?
>> Cheers,
>> Henning
>> Below the complete output after "make" in the diglib directory:
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
