[GRASS-dev] winGRASS Self Installer Package
marco.pasetti at alice.it
Thu Mar 6 09:48:05 EST 2008
Hi Benjamin,
I'm afraid, but I cannot find the thread...
I'm very close to finish the installer; these my questions:
1) name diplayed in the installer: GRASS 6.3.0RC5 or GRASS 6.3.0RC5 for Windows or simply GRASS 6.3?
2) MSYS files: I decided to include the whole MSYS env, excluding MinGW, obvioulsy; list follows:
basename.exe
cut.exe
false.exe
id.exe
ls.exe
mv.exe
sed.exe
tar.exe
uniq.exe
bzip2.exe
date.exe
find.exe
info.exe
m4.exe
od.exe
sh.exe
tee.exe
vim.exe
cat.exe
diff.exe
fold.exe
infokey.exe
make.exe
patch.exe
sleep.exe
texindex.exe
wc.exe
chmod.exe
diff3.exe
gawk.exe
install-info.exe
makeinfo.exe
ps.exe
sort.exe
touch.exe
xargs.exe
cmp.exe
dirname.exe
grep.exe
install.exe
md5sum.exe
rm.exe
split.exe
tr.exe
comm.exe
env.exe
gzip.exe
less.exe
mkdir.exe
rmdir.exe
stty.exe
true.exe
cp.exe
expr.exe
head.exe
ln.exe
mount.exe
rxvt.exe
tail.exe
uname.exe
what to keep, what to remove?
3) bin executables: there are actually some usefull apps to add; thi is the list of my /bin exes (I built a brand new msys env with grass only needed libs):
XMLTester.exe
flex.exe
gdalmanage.exe
invgeod.exe
ogrtindex.exe
tiff2bw.exe
tiffinfo.exe
bison.exe
gdal_contour.exe
gdaltindex.exe
invproj.exe
pal2rgb.exe
tiff2pdf.exe
tiffmedian.exe
bmp2tiff.exe
gdal_grid.exe
gdaltransform.exe
m4.exe
ppm2tiff.exe
tiff2ps.exe
tiffset.exe
cs2cs.exe
gdal_rasterize.exe
gdalwarp.exe
nad2bin.exe
proj.exe
tiff2rgba.exe
tiffsplit.exe
fax2ps.exe
gdal_translate.exe
geod.exe
nad2nad.exe
ras2tiff.exe
tiffcmp.exe
fax2tiff.exe
gdaladdo.exe
gif2tiff.exe
nearblack.exe
raw2tiff.exe
tiffcp.exe
fftw-wisdom.exe
gdalenhance.exe
gsl-histogram.exe
ogr2ogr.exe
rgb2ycbcr.exe
tiffdither.exe
flex++.exe
gdalinfo.exe
gsl-randist.exe
ogrinfo.exe
thumbnail.exe
tiffdump.exe
Thanks
Marco
Da: grass-dev-bounces at lists.osgeo.org per conto di Benjamin Ducke
Inviato: gio 06/03/2008 15.15
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: [GRASS-dev] winGRASS Self Installer Package
I remember dimly that we discussed these things before, a few
weeks back when I was trying to put together a new WinGRASS
distribution. I think that Glynn posted a list of useful tools for
inclusion to this mailing list, back then.
There are other useful things, such as wget, curl, tar, unzip, awk,
sed, ...
Some of them may be needed by shell scripts.
Maybe it would be a good idea to put up a Wikipage and start
adding these things to it?
Benjamin
Paul Kelly wrote:
> On Thu, 6 Mar 2008 marco.pasetti at alice.it wrote:
>> Hi,
>>> First of all, I want to express my thanks on behalf of students here
>>> who are using GRASS on Windows [...]
>> you're welcome... did you already read my new GRASS Windows Native
>> Binary Building Guide?
>> http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html
>> <http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html>
>> I'm updating it with packaging instructions
>> when I'll have enough free time I'll put it into GRASS trac
>>> My suggestion is that you include SQLite but not PostgreSQL.[...]
>> Do you think that libsqlite3-0.dll is enough? in my (built) sqlite
>> directory I have /bin with 1 dll and 1 exe, /include with only
>> includes and /lib dir with static libs.
> If you've compiled GRASS against the .dll then you don't need the static
> libraries. If you've compiled GRASS against the static libraries then
> you don't need to include anything - the required libraries will be
> statically linked into the GRASS modules (you can usually tell this if
> the size of the binaries is very large. I usually delete the static
> libraries after compiling to make sure they are not picked up by
> accident). You certainly don't need to include the header files in
> include/ for a binary distribution - they are only necessary for
> compiling. If there are some useful utility programs in bin/ they may be
> worth sticking into the GRASS bin directory too, e.g. gdalwarp.exe and
> gdalinfo.exe from GDAL and cs2cs.exe and nad2bin.exe from PROJ.
> For a lot of packages though you just need the DLL and can stick it
> straight into the GRASS $GISBASE/lib directory before packaging up the
> binary distribution.
> Paul
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke at oxfordarch.co.uk
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080306/398ebcd2/attachment-0001.html
