[GRASS-dev] Re: GDAL 1.5.0 Build Error With GRASS Support
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Fri Mar 7 05:58:50 EST 2008
Has anyone had success with the grass-gdal plugin an MinGW?
For me, it just always produced Linux style .so files.
Cheers,
Benjamin
Markus Neteler wrote:
> Hi Marco,
> (cc Frank)
> I assume that the plugin for gdal 1.4.3 also works for gdal 1.5.0.
> Markus
> On Tue, Mar 4, 2008 at 10:51 PM, Marco Pasetti <marco.pasetti at alice.it> wrote:
>> Hi Markus,
>> I already checked it out... but it seems that there's still not a
>> grass-plugin for latest gdal release (1.5.0); the last I found is for gdal
>> 1.4.3
>> Marco
>> -----Messaggio originale-----
>> Da: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Per conto di
>> Markus Neteler
>> Inviato: martedì 4 marzo 2008 22.41
>> A: Marco Pasetti
>> Cc: grass-dev at lists.osgeo.org
>> Oggetto: Re: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
>> Hi Marco,
>> please don't build GDAL with direct GRASS support but use the plugin instead
>> (way easier...). See
>> http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GD
>> AL/OGR_Plugin
>> cheers
>> Markus
>> On Tue, Mar 4, 2008 at 9:24 PM, Marco Pasetti <marco.pasetti at alice.it>
>> wrote:
>> > Problem fixed
>> > needed only to add --with-local=/usr/local in configure
>> > Marco
>> > ________________________________
>> > Da: grass-dev-bounces at lists.osgeo.org
>> > [mailto:grass-dev-bounces at lists.osgeo.org] Per conto di
>> > Inviato: martedì 4 marzo 2008 18.03
>> > A: grass-dev at lists.osgeo.org
>> > Oggetto: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
>> > Hi,
>> > I'm building GDAL 1.5.0 with GRASS support; it gives the following
>> > error:
>> > In file included from grass57dataset.cpp:45:
>> > C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:23:22:
>> > proj_api.h: No such file or directory In file included from
>> > C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:36: error: ISO
>> > C++ forbids declaration of `projPJ' with no type
>> > expected `;' before '*' token
>> > make[2]: *** [../o/grass57dataset.o] Error 1
>> > make[2]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts/grass'
>> > make[1]: *** [grass-install-obj] Error 2
>> > make[1]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts'
>> > make: *** [frmts-target] Error 2
>> > proj_api.h is present in /usr/local/include, while
>> > /usr/local/grass-6.3.0RC5/include/grass has gproj_api.h should I force
>> > GRASS code to include gproj_api.h instead of proj_api.h or walk around
>> > the problem adding /usr/local/include to PATH before launch make
>> > command?
>> > Thanks
>> > Marco
>> > _______________________________________________
>> > grass-dev mailing list
>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Open Source Geospatial Foundation
>> http://www.osgeo.org/
>> http://www.grassbook.org/
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke at oxfordarch.co.uk
