R: [GRASS-dev] Re: GUI support for TclTk
8.5
Gerald Nelson
gnelson at uiuc.edu
Mon Mar 10 09:01:20 EDT 2008
I'd like to see the new version, with warning. Jerry
---- Original message ----
>Date: Mon, 10 Mar 2008 13:23:42 +0100
>From: <marco.pasetti at alice.it>
>Subject: R: [GRASS-dev] Re: GUI support for TclTk 8.5
>To: "GRASS developers list" <grass-dev at lists.osgeo.org>
> Hin
> NVIZ works fine for me, with tcl/tk 8.5.1
> BTW, I just finished the installer for windows, but
> there's still a problem I'm not able to fix:
> installer procedure creates 4 different files to let
> GRASS work even if installed in dirs with spaces;
> files are:
> grass63.bat
> grass63 (to launch grass from msys shell)
> msys.bat
> grassrc6 (to avoid initial location error)
> It works fine, but nviz fails if GRASS is installed
> in a "spaced" dir; I verified that error doesn't
> occur when installed in a "space free" dir!
> I could release it right now (actually, after lunch
> ;-)), warning in the install procedure to not use
> dir with spaces, or delay the release and try to fix
> the problem.
> What do you think about?
> Marco
> Da: grass-dev-bounces at lists.osgeo.org per conto di
> Maris Nartiss
> Inviato: lun 10/03/2008 13.14
> A: GRASS developers list
> Oggetto: Re: [GRASS-dev] Re: GUI support for TclTk
> 8.5
> Probably problem is mixed back and forward slashes
> within single call?
> Please, open new ticket for this (hardcoded paths in
> nviz).
> Maris.
> 2008/3/10, Paul Kelly
> <paul-grass at stjohnspoint.co.uk>:
> > However, in a bit of further testing this morning
> I've discovered a new
> > error that appears from different sources:
> > couldn't duplicate input handle: bad file number
> > while executing
> > "exec $src_boot/bin/g.gisenv GISBASE"
> > (procedure "Nv_makeGUI" line 13)
> > invoked from within
> > "Nv_makeGUI.top"
> > (file
> "s:/grass/trunk/dist.i686-pc-mingw32\etc\nviz2.2\scripts\nviz2.2_script"
> > line 1025)
> > Paul
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
>________________
>_______________________________________________
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
